Ah,
so it is a bug then - I had wondered. I also ran into problems when trying
to dynamically run a large application. In the end I got around it by decreasing
the number of dynamic calls (and upgrading the control computers spec accordingly),
but that wasn't exactly the ideal solution. I was using LV5, and I would
be curious to hear if there is a fix for this in LV6.
Cheers,
Ben
"Michael Fortenberry" wrote:
>>>I contacted NI Tech Support several months ago with a problem calling
a sub>VI dynamically in an executable using LV 6. >>I have a very large
application built in LV 5 that uses numerous dynamic>calls to control data
acquisition and command handlers. When I ported the>application to LV 6,
everything worked fine in the development
version, but>the dynamic calls
did not work when the application was compiled into an>executable. I know
all of the path references are correct since the code>works fine in LV 5.
>>I sent a very simple example of the problem and my results to NI Tech
Support.> After several e-mails and phone calls, they acknowledged that it
was a bug>and would be forwarded to the development team. Well, 6.0.1 is
out and I>tried it again and still no luck. >>I was wondering if anyone
else has run into this problem. >>Alternately, I was wondering if anyone
else has successfully called sub VIs>dynamically in an executable in LV 6.
If so, I would love to find out how>you did it.>>_______________________>Michael
Fortenberry>G Systems, Inc.>
