Problem with database connectivity toolkit
I have problem with Labview database connectivity toolkit. I build and deploy the real_web.vi (attached to the post) to the web server. It seems that the DB Tools Open Connect can not connect to the data base, and it issues the following error:
	NI_Database_API.lvlib:DB Tools Open Connec (String).vi->real_web.vi->real_web.vi.ProxyCallerADO Error: 0x80004005 Exception occured in Microsoft OLE DB Provider for ODBC Drivers: [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified in NI_Database_API.lvlib:DB Tools Open Connec (String).vi->real_web.vi->real_web.vi.ProxyCaller
But in highlight execution, I do not get this error! My program connects to the database and read the data. What is wrong ?
Moreover, when I connect to the vi using the web-browser, the cpu usage of ApplicationWebServer process goes up to 100% (The same problem as stated in this post).
(5,848 Views)
Say what you will about the problems that the DCT can cause (and goodness knows I have) my suspicion is that this is not a toolkit ptoblem. When ever something only works with execution highlighting on, two words should immediately jump to mind: "race" "condition".
Execution highlighting will muck aound with the order in which things get done in your code. Can you post what your code looks like?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(5,831 Views)
Thank you mikeporter for the reply. I have already attached the code to the first post.
But, I found the problem yesterday. The problem was (as labview complained) about the ODBC. Previously I defined my database DSN under User DSN, but now I moved it to System DSN. As a result, everything is working smoothly! (although it seems a little bit odd).
(5,818 Views)
This is more than a bit odd. The code should work the same regardless of whether or not execution highlighting is on. I would still want to know why the error went away with highlighting on.
Mike...
LabVIEW Champion
(5,809 Views)
