Problem with data updating in arrays
Hello. I got a problem with updating data into arrays. As you can see in my file, after you run the program, when I try to change the values in my data stream, the values aren't updated in the arrays, as well as in the chart. It should be updated because when I turn on the highlight execution switch, it is working properly. I am not sure if it is about the delay timing functing or not. I tried to add them but it's still not wroking
(2,589 Views)
Hello. If i understood you right, the only problem are the values you type in after starting your programm aren't just updated.
I changed your VI a little and in my oppining it seems to work. Take a look at the screenshot i took.
I hope this solves your Problem.
Best regards.
(2,560 Views)
(2,546 Views)
