Problem with creating VI's from DLL in LabView 8.5
I think I've found an issue in LabView 8.5!
I want to create VI's from a DLL that I've created by myself. (with the DLL import assistant)
In LabView 8.2 it works very well and the VI's will be correct created.
But when I use the DLL-Import-Assistant under LabView 8.5 it works correkt up to the creation process of the VI's.
At this position LabView won't do anything!
I've done a screen-shot of the creation process.
What I say is: It works under 8.2 but NOT under 8.5!
(2,744 Views)
I seem to remember that this is a known problem and there should be a post somewhere here where someone from NI posted a fix you have to copy into vi.lib for this to be fixed. If my memory only would tell me when and where I read that.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(2,733 Views)
>> ...a fix you have to copy into vi.lib for this to be fixed.
Thanks for your response but your solution doesn't works in this case.
Any other ideas?
Best Regards
Patrick Röth
(2,727 Views)
Any other ideas?
Best Regards
Patrick Röth
Ok I checked and there are following similar issues each with their own CAR number.
Recommends to repair LabVIEW installation
A conflict between LabVIEw 8.2(.1) and 8.5 import wizard, when both versions are installed, use 8.2 ...
Rolf Kalbermatter
(2,718 Views)
