Problem with control could not be loaded
When I try to run this program, the graph shows control could not be loaded. After installing NI LabVIEW Run-Time Engine, the problem is still there.
I am trying to find a solution.  Any help would be greatly appreciated.
(5,911 Views)
Accepted by topic author ice4817
The LabVIEW runtime engine is irrelevant for this. Looks like you are missing the OL-770 activeX controls.
(5,906 Views)
After repair the SDK, it is loaded. Thank you so much!
(5,884 Views)
What you mean with SDK , I have the same problem.
(5,851 Views)
May you help to share your SDK of OL770 here?
(2,581 Views)
