Problem with comparing (excel related)
Problem: Basically all the vi does is grab values from excel and compare it with a pre-determined value and if the returned value is greater than or equal the vi stops and returns the cell which gave it thar value. I think it may that I am telling excel to compare a string value to a decimal value but I have tried that and it seems to stop instantly with a value which is cleary wrong.
I have attached the vi and  sample excel file which it searchs through
(2,981 Views)
Accepted by topic author MrSafe
Don't see a problem. Start at A4 and it stops on the first iteration as it should (because the cell is blank it converts to a 0 which is greater than -30). Starting at A5 it steps down to A368, again just as it should.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,962 Views)
Did you do anything to the vi to get that result? for me the result is ALWAYS A5 which is incorrect.
(2,943 Views)
I managed to get it to work. I am not even sure how because I didn't do anything.  But it works now, thanks!
Message Edited by MrSafe on 02-10-2009 12:51 PM
(2,939 Views)
