Problem with calling avi file
I send here the problematic vi. I build an array of strings with for this example, 2 video files to play succesively.
It is in fact a subvi of a main vi that calls this subvi at different times.
I have also a problem to call the subvi to the state that remains at the last call (so in this example dieudo 1 is playing at the call 1 and at the call 2 dieudo 2 is playing) this despite the fact that I use close afterwards option.
Thanks in advance for your help.
(2,537 Views)
It is noteworthy to say that when I call the film with a path function and a converter to string, the film is running.
The problem seems be located in the array of strings but I do not understand why because it functions with mp3 file??
(2,521 Views)
