Problem with broken wires in sequences
I have a rather strange problem with sequences in LabVIEW 6 (also 6.0.2).
I use a sequence which contains some VISA VIs, which resource and error inputs/outputs are passed to the next frame. I came across the rather strange problem that I get broken wires whenever I put something into frame No. 1 and connect a VI output to a tunnel. (It always happens exactly to frame No. 1! The same contents in frame No. 0 or 2 or anything else is accepted!)
I have included a small demonstration VI, including just a sequence with three frames, each one containing a VISA serial write VI. Although all frames contain the same, frame No. 1 has broken wires. BTW, it does not depend on the VI employed; it happens even when the input
tunnel is just connected to the output tunnel.
What may be the reason for this rather strange behaviour? Did I make some mistake? Or how can I solve this issue.
Thanks in advance for your help!
Greetings
Kristian Laß
(2,654 Views)
Hi
The problem is that you cannot wire from different frames to the same tunnel in sequence structures! That's impossible. You have to replace the sequence structure with a case structure inside a while loop. Check my little example.
Luca P.
Application Engineer
Luca
(2,654 Views)
Hello, Kristian Laß
When you use secuence, only one frame can get out your variables.
So you have number of ways how to solve this issue:
1) Don't use secuence, use while (for) cycle with case into (see example)
2) Use secuencal local (this method is not good)
3) Use number of secuences each with one frame only
(2,654 Views)
