Problem with array
I am so so sorry guys to ask once again 😞
I just found ,that column 0 must be multiplied by 2, col 1 by 5 , col 2 by 6, col 3 by 8.
And the program that Geoff sent me, it multiply all elements of the array by 2. I am wondering, how to multiply each column by several number.
Sorry, i can't find the answer.
Thanks a lot
Maxwell
Message 11 of 16
(1,524 Views)
Hallo Thomas,
Thanks , but i can not find the attachment that u meant. May be u forgot to attach it ?
Max
____________________________________________________________________________________________________________________________________
Maxwell
Have a look at my vi or the picture ulf attached. This solution has several advantages in comparison to the one you want to use:
1. It needs less memory, because you do not have two for-loops
2. It's easier to understand
3. It's faster
So I suggest you to use our version.
Thomas
Using LabVIEW 7.0 on WinXP
Message 12 of 16
(1,519 Views)
Hello Maxwell,
please have a look at the attached vi.
Just use the indexing of the for-loop to get the single columns and multiply with your vector.
Message 13 of 16
(1,515 Views)
Hello Maxwell,
again as LabView7.0...
Message 14 of 16
(1,512 Views)
Here's a solution more along the lines of what the guys were saying was more correct earlier...
It's a little easier to look at anyways... (in 7.0)
Oops, hang on...posted wrong vi
Message Edited by Novatron on 06-29-2005 09:52 AM
Message 15 of 16
(1,507 Views)
Sorry about that, got a lot of things going on...
Here's the real one.
Message 16 of 16
(1,496 Views)
