Problem with XY Graph looking like a scribble
Two questions:
1) The in range and coerce module, the wire that runs from the In-range? Output, does that delete data not in range?
2) I don't understand the use of imaginary values when constructing the plot.
Mike
Mike
Message 11 of 26
(785 Views)
@MikeBowen wrote:
Two questions:
Mike
  1. it will output the value coerced to the limits, but since the conditional tunnels skips all out of range data it does not matter either way.
  2. XY plots understand a rich set of datatypes:
  • An array of points (each "point" is a cluster of scalars x and y)
  • A scalar cluster containing x and y 1D arrays
  • A 1D complex array where RE=x and IM=y (my personal preference!)
  • combinations of the above for multiple plots (but all plots must be of the same type!)
  • etc.
Message 12 of 26
(783 Views)
You lost me on the tunnel.
Mike
Mike
Message 13 of 26
(773 Views)
Here's the light at the end of the tunnel... 😄
The autoindexing output tunnel skips elements where the boolean is false.
(right-click...conditional)
Message 14 of 26
(767 Views)
The final for loop, does that code modify the curve?  The picture I got was very sinusoidal.
Mike
Message 15 of 26
(746 Views)
Recommendations:
 - Format your data file to be consistent.
   - Same number of columns in every row
   - Have a dedicated column for each sensor
   - Sort data by date.?
 - In your code, if you want to process and view the data chronologically, you should sort each sensor/channel by the date/time
 - In your display, you can just show points:
Edit: Sorry, I was staring at a cached version of the thread when I started responding, so I missed that Altenbach and OP have been active.
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
Message 16 of 26
(743 Views)
No, it does not modify any data, it just unbundles the data as sorted by time.
I don't see anything "sinusoidal". Are you talking about the slow or fast oscillations?
Message 17 of 26
(732 Views)
I took a look at the first rev code which plotted against time index, and it was sinusoidal in nature in that it was up and down.  This data has the same repetition, so it's my bad.
The other plots are intermittent in nature, which makes it hard to see that data.  I probably need to blow the data up and look at it slowly.  Any recomendations on how to look at the notes?  When I pull out the data I will add the notes and make that available, but it could involve a hundred or so points to look at.
Mike
Mike
Message 18 of 26
(727 Views)
If the fast oscillations are noise, you could filter the data.
I would just add the note (I assume there is only one note for each time point and time points don't contain duplicates) as a string to the cluster. Each cluster will have a time, an array of values from the various sensors, and a string for notes.
Message 19 of 26
(724 Views)
Here's how that could look like....
Message 20 of 26
(721 Views)
