Problem with Writing data to AB PLC using RSLinx and DataSockets
Hi
  I am trying to write a value to a input registry of a module in AB logix 5000 plc using RSlinx opc server and datasockets. I have used the datasocket write to accomplish this, but the value that i give is written to the plc but it being switched between 0 and the user defined values for every 20ms. But I want to send a constant value to the PLC.
 I am attaching the vi I have created , plz go through and modify if necessary and give me some feedback about this.
I am a novice at labview so plz help me out. I tried to find simple examples on datasocket write but couldnt find any simple ones.
Thank you
Anand
(2,985 Views)
Anand,
If you remove the while loop and write a single value to the PLC does it not maintain that value?  It is possible that your very fast loop rate in you VI is causing the PLC to miss values, but I don't know why that would be converting it to what looks like the default value.  I might verify that you have the OPC server set up correctly.
Please let me know how this turns out!  Thanks!
Andy F.
(2,970 Views)
Hi Andy,
  I have got the problem fixed, instead of assign a input module bit I have just used normal tag and tried the same program and it worked.
Thanx for the help
Anand
(2,967 Views)
