Problem with Waveform Chart X scale
But if you are going to post a VI for a demo, you should at least make it a good demo.  Having someone constantly change the Xscale offset of a chart with the current time in a loop is just plain wrong and is going to really confuse an inexperienced LV programmer when they can't figure out why their VI isn't working correctly.
Message 31 of 48
(1,649 Views)
I think it is working. And he was having doubt about X-axis, as per the PC time X axis time is changing.
I am sorry if it is confusing and I will try not to repeat it
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 32 of 48
(1,647 Views)
@Ranjeet_Singh wrote:
Please dont judge the VI which is posted only for demo. I just want to show him the settings for X axis.
But your settings for the X axis were completely wrong! It is a serious mistake to rewrite t0 with every iteration of the loop. I had to say something to make sure the OP does not try to use your suggestion.
(Edit: Just noticed Ravens comment above. He already expressed what I wanted to say)
Message 33 of 48
(1,640 Views)
Sir
--Ranjeet
Message 34 of 48
(1,627 Views)
Check here.
Message 35 of 48
(1,623 Views)
Hi guys.
Very thanks for your help.
I used your suggetions for x-axis. And the x-axis works very good, i found my true problem: the plot. I changed x-scale and the plot don´t change. The waveform chart printing the values in same interval, independent of x-axis.
I don´t understood why??? My head are sick because it 😕
Icaro Kossmann
LabVIEW 8.6 Newbie.
Brazil
Message 36 of 48
(1,610 Views)
What do you mean by "same interval". Can you show us a picture. Then explain what you expect to see instead.
Message 37 of 48
(1,603 Views)
So, i printed screen of two acquisitions. Both them were executed in 8 min. First image grafico10min, the x-scale has 10 min interval. Second image has 60 min interval. How you seen i changed the x-scale, but the graphics plot the points equally, indifferent of the scale in x.
Icaro Kossmann
LabVIEW 8.6 Newbie.
Brazil
Message 38 of 48
(1,592 Views)
Did you change the xaxis.multiplier accordingly?
How did you "change" the x-scale? You need to give more details! Whenever you change the rate, you should probably clear the graph. Do you?
Message 39 of 48
(1,585 Views)
Yes, i changed the scale.multiplier in both cases. But i cleared the chart in each acquisition.
But  same changes the x-scale and cleaning the chart. The points continues how there no alterations.
Icaro Kossmann
LabVIEW 8.6 Newbie.
Brazil
Message 40 of 48
(1,579 Views)
