Problem with Scan Value Function
Hello everyone,
I have a problem with this function. I send data with arduino using VISA, with string format. The problem is: if I send "28,30" there is no problem, it reats 28,30, but if I send "28.30" it reads the value 28,00. I have already tried with %f. %.; and I can`t find a solution. Smiley Frustrated
Best Regards,
Jose S.
(4,195 Views)
Accepted by topic author Corzu
Use %.;%f as format string.
Regards, Jens
Kudos are welcome...
(4,174 Views)
I'm guessing that you are using the comma (,) as a "decimal separator", i.e. 28,30 means 28-and-30-hundredths (what I would write as 28.30, as I use a period instead of a comma).
By default, LabVIEW should use whatever your PC uses as the default, so the string "28,30 28.30" read with format "%f %f" should give you "28,30" and "28", that is, a 4-digit floating decimal number and a two-digit number, with the period signalling to LabVIEW to stop scanning because a non-floating-point-character (the period) was encountered.
You can set the comma or period (or set "use what the PC uses") by putting the Format code %,; (use comma), %.; (use period, or %; (use system default).  Thus if you wanted to read "28,30 28.30" as two floats, and you knew the first used a comma, the second a period, you would specify "%,;%f %.;%f" (you specify the separator before specifying that you want to parse a Float).
You can find this yourself by reading the Help for "Scan from String" and then clicking on the "format string" link in the Help text.
(4,155 Views)
Thank you! very well explained.
Best Regards,
Jose S.
(4,121 Views)
