Problem with Reporte Generation Toolkit for Microsoft Office 2010
When I use the Report Generation Toolkit (LabVIEW 2010), and Office 2010,  the tables generated are bad.
In office 2007 in the tables are correct.
Someone can help me solve this problem?
(4,013 Views)
Hi Jbatista,
there aren't compatibility problems between RGT (labVIEW 2010) and Office 2010, as you can see at this link: http://digital.ni.com/public.nsf/allkb/C9408B9F08D711E786256F3300701D01?OpenDocument
Maybe there were some installation problems when you passed from Office 2007, to Office 2010, so you can try to install Office 2010 before installing the Report Generation Toolkit and see if it works properly.
Bye
(4,003 Views)
The solution referenced in your post does not actually workas far as I can tell... at least for LV2011 and Office2010 on Win7
Am I missing something here?
(3,911 Views)
Using the LV 2011 version of the Append Table to Report VI does not work either it seems...
(3,909 Views)
There is some other bugs for sure when dealing with column and row headers.  I believe if you don't have column or row headers the NI work around works.  I had to have column headers and ended up modifying NIs fix to try to get it to work with some success.
(3,899 Views)
