Problem with Property Node (export image)
HI there,
I am having a problem with the create - invoke node - export image command.  I basically take a measurement with a signal analyzer, dump it to a graph and try to save the image.  The save is only working approximately 50% of the time.  It seems to not work when I run the vi without highlighted exectution or I put probes all over the place.  It does not seem to run when I start it right up.  I usually get some kine of error like "the filename contains an unallowed character such as @ or ?".  My file names have neither of these characters.  They do have a + and a - in them.  I don't understand why the vi only works sometimes.  Anyone have this problem.or any ideas how to fix it?
(3,411 Views)
I changed the file names and still have the same problem.  The vi saves the images if I run it alone.  The second it as a subvi it does not save.  I am throughly confused here.  Any help anyone?
(3,387 Views)
Can you post some code demonstrating the problem? Also what version of LV are you using?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,380 Views)
