01-22-2007 09:37 AM
01-23-2007 09:00 AM
01-23-2007 09:37 AM
01-23-2007 10:09 AM
Why are you copying this VI from one machine to another? It's a shipping VI with LabVIEW...why not just use the installed version of that VI in the LabVIEW you have on each machine?
-D
01-23-2007 10:24 AM
Hello Darren,
we have modified this VI to get a print preview. We added another control to the connector pane indicating to print or show print preview and used another OLECMD in the case we want the print preview. Also we moved and scaled the Active-X container and open the front panel when we want the print preview. This modified VI got the problem described here.
I just want to test if this behaviour results from our modifications or is also existent in the original VI I copied just the original VI and got the same result.
The VI installed on my machine works fine on my machine and on the other machine.
03-15-2007 03:04 PM
