Problem with Labview example
I am using the Labview example : "Agilent 34401 Acquire and Graph - SW Triggered". It is configuered so that it takes 100 samples every 100ms and then plots it. In order to launch it several times in a row, I have put it in a while loop and set the trigger to 1.
 It works ok for the 4 or 5 first loops and then the "Fetch VI" sends a timeout error : "L'erreur -1073807339 s'est produite à : VISA Write dans Agilent 34401.lvlib:Fetch (Internal Buffer).vi->Agilent 34401 Acquire and Graph - SW Triggered.vi"
Would anybody know how to solve this problem? I have set the wait clock of the trigger loop to 4000ms ( 6000 ms ). I suppose this doesn't mater because I am not doing a second round of loop.
PS : I don't want to use several triggers because I need to fetch the info at the end of each trigger.
Many thanks,
Marc
(2,987 Views)
You can see if the modified read VI mentioned here fixes your problem.
(2,971 Views)
Hi Dennis,
thanks a lot for your answer. Great help to know there is a pb with the Drivers.
Marc
(2,932 Views)
