Problem with LabVIEW Library File (.llb)
I would be grateful if you could advise me on a LabVIEW issue I encounter ( I am a new LabVIEW user).
For my set up I use a customised development tool through the LabVIEW GUI that depicts the waveforms obtained from a sensor and measures the vital signs of my interest. That is run through a .llb file named  monitor.llb  on a win 7, LabVIEW version 14.0f1 (32-bit)  PC.
I am trying to run the same file on a win 7, LabVIEW 2015 PC and it seems, as you will notice on the attached photos, that some PROC.GLOBALS.vi are missing. I searched that in such case they have to be replaced because they are either renamed or lost.
According to this the missing global variable is dimmed like in my case. This means that It has been moved, deleted, or its name has changed.
I am also trying to run the same file on a different PC with the same windows and labVIEW versions as the first one, in order to avoid compatibility issues, with the difference that on this case  all the PROC.GLOBALS.vi are present and no error message is appearing but unfortunately  it is still not functioning.
I would appreciate it if you could give your advice.
Thank you in advance
Panos
(4,851 Views)
Are you using a Project at all?  From what I am seeing, if you used a project the global VI should be found.
(4,838 Views)
On the first PC I am just opening the LLB manager named 'MONITORv0.990 - Working.llb' , I run [MONITOR].vi and then it perfectly works.
Once I copied the .llb file to the other two computers, I am facing the problems mentioned above.
- PC A) win 7, LabVIEW 2015, PROC.GLOBALS.vi are missing
- PC B) win 7 LabVIEW 2014f1, no errors appearing but still not functioning as on the first PC
(4,818 Views)
Hi pblanos,
So the VI containing those globals is missing. You need to copy it too…
It would be better to use a real project in LabVIEW.
And so much better to use this project to create an EXE and an installer to install your EXE on those other computers!
- Start by moving all those VIs/files from your LLB into their own folder. (LLBs shouldn't be used anymore.)
- Then open your main VI (Monitor?), then select Project menu -> new project. Then a dialog opens where you can include your main VI (and it's dependencies) in a new project…
- Don't forget: do the LabVIEW basics to learn how to use projects at all…
(4,797 Views)
GerdW,
I followed your steps, and I really thank you for this, I even included VISA resource settings in the installer, but unfortunately the problem remains the same.
I don't know if I have to include anything else in general to my LabVIEW installation, at this point it is becoming confusing.
Also the fact that I was not the creator of the VI's as well as that I am a new LabVIEW user doesn't help a lot.
(4,768 Views)
Hi pblanos,
when you have problems with your VIs/LLB you should attach those VIs/LLB here so we can examine the problems more closely. Point.
As is for us. It really doesn't help when all we get are some images of error messages…
(4,764 Views)
