Problem with LabVIEW 7.1 on Win2000
I just installed LabVIEW 7.1 on PC with Windows 2000 operative system. The installation process was just fine. However, whenever I reboot I get an error massage (see attachment). Is there anyway of solving this problem?
(2,821 Views)
Dear Ali,
it seems that you have installed Vision driver components but not any Vision products. If do not plan to use Vision products goto the Control Panel>>Add/Remove programs and use "National Instruments Software" to remove all Motion & Vision entries in the setup.
When starting MAX will be loaded and searches for all components. For some reason it searches for the IMAG configuration manager.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,804 Views)
@waldemar.hersacher wrote:
Dear Ali,
Thank you for your response. However, I could not find any trace of Motion or Vision components. Therefore I uninstalled LabVIEW and installed everything again. Now, things are working perfectly. But I do not know why. We had installed Motion and Vision on this machine previously but they were uninstalled before the installation of LabVIEW 7.1. However, before installing the LabVIEW, we did not restart the PC. Could it be this which was the problem?
(2,774 Views)
