Problem with LVSFL ... vpsflapi.dll ?
Hello I'm using the lvsfl library for controlling JTAG in a particular setup. I copyed all the vis from the pc I was working on before (in another country) but I didn't copyed the file needed for all these vis to work, that is vpsflapi.dll
Does anyone know how to handle this problem? Do I have to search for something that can install LVSFL on my computer or I just need to find this .dll file and copy it at the right position in my LabVIEW 7 directory?
(2,635 Views)
Hi, you definitely should find something that installs the whole package in your new pc. Other dll, activeX or header files could be needed.
If you can't find any installer you could copy the dll to the right folder and register it in your system with the "regsvr32 nameOFtheDLL" command.
If that dll is all the driver needs to work, this should be enough.
ciao
NicolaC
(2,635 Views)
