Problem with IMAQROIprofile!
Question no 1. Does anyone know if the vi IMAQROIprofile only accepts an 8
bit´s image or if it´s possible to use any kind of image ?
Question no 2. If you use a property-node in your vi, does the system takes
the "default values" configured in MAX ?
//Magnus
(2,617 Views)
Hello Magnus,
The IMAQROIProfile.vi will accept 8, 16 & floating point image types.
- The Online Help for the VI will document what image types are supported.
When using the Property Node, it usually follws the IMAQ Init to get the IMAQ Session.
- When IMAQ Init is called, it will start with the default values you set in MAX.
- When the Propertiy Node follows, it updates the values with the new ones.
(2,617 Views)
