Problem with Hantek DSO3064 driver
I have used "scope.vi" from hantek with following problems:
1. There is 0 information about the dll functions, I had to use trial/error and investigate the H and cpp files
2. After a lot of work I made work such horrible interface BUT I can not increase buffer size to more than 30k (nor 1M,2M,...), because when increasing over 30k it is rewritten partially de memory and if I inctrease to more than 100k it is hanged and I have to disconnect from USB to avoid restarting windows 7
3. I can not find any relay control for 1x and 10x scope probes
(5,043 Views)
There is no driver from NI for that instrument. If you got it from the vendor, you should first check with them.
(5,020 Views)
Hi, I was wondering if you could offer advice. I tried to run your scope_v10.vi and get these errors (attached), are you able to advise? Thanks Narra
(4,476 Views)
It appears that you do not have the dll needed installed.
(4,470 Views)
I have the DLL that came with the labview code "demo" provided by the manufacturer (attached). Not sure why it's not working.
(4,466 Views)
If you click on the Call Library node you will see that it is looking for the dll in a particular directory, see picture. YOu can try changing the directory to where your copy of the dll is loaded and see if that works.
(4,463 Views)
I got it! Modern legacy issues, I needed to be running in LV 32bit not 64bit.
Thanks for your help, it led me to stumble on the answer!
(4,459 Views)
