Problem with Graphs/Charts
Hello all,
I would like to display a function (e.g. y=x*x), but it should be
displayed pixel by pixel. The VI should have X_min, X_max, and delta_X
and the time delay between two pixels appearing in the display as
inputs. Couldn't manage it with a waveform chart because it doesn't
accept an arbitrary x-value. On the other hand, I couldn't manage it
with the graphs (waveform graph) either because they only accept whole
blocks (arrays), but it should be displayed point by point.
Any help would be appreciated
Bye
Johannes
(2,980 Views)
Have you looked at the shipping example called XY Chart? To quote from the VI's documentation:
"This VI illustrates how to make an XY Graph behave like an XY Chart, in which the plots appear to update incrementally. This implementation uses a reentrant subVI (XY Chart Buffer.vi) that stores the plot data, appends the new data, and removes old data in excess of the chart history size."
(2,980 Views)
Hi Dennis,
thanks for your answer.
The XY Chart comes near to what I want. I still face some problems.
What I actually want to do is to simulate an unbuffered DAQ card. I
want to create VIs that send a point at a time (x,y) beginning at
x_min, raising each time the x value by delta_x, and stopping at
x_max. So I do have constant increments of x, I don't have to create
something sophisticated like a spiral or ellipsis. I have tried to
build a simple VI containing the XY Chart Buffer.vi.
x_min, x_max, and delta_x are controls in my VI. Basically the VI
consists of a while loop with a shift register. First, x_min is
connected to the shift register and routed to the function-VI inside
the loop (as the first x value). The output of the function-VI is the
first y value. x and y are bundled and routed to the XY Chart
Buffer.vi. This vi is connected with the XY Graph as usual. The x
value is added by delta_x and the sum is routed to the shift register.
It will be the x value in the next iteration if it is still <= x_max.
Otherwise the loop terminates. There is also a metronom inside the
loop to simulate delays. The function-VI is the Step Function.vi
Unfortunately the XY Graph doesn't scale correctly. If I use +/-10 for
x_min and x_max, then the chart displays the points between +/-1, if I
use +/-1 then the chart displays them between +/-0.1. There is always
a shrinking of 10 (also delta_x, but y is ok) and I don't know why. I
don't want the points to be connected, how can I do that.
I feel that the Waveform Graph is probably better then XY Graph in my
case since it seems to have more options. I have tried to build the
Graph array out of the former Graph array and the new y value. It
works, but I got problems with array/cluster/type combatibility when I
try to include x0 and dx (connect a cluster with x0, dx, and the
accumulated y values with the Graph). Sometimes Labview seems to get
confused with the array dimensions. It interprets the Graph array to
be multidimensional. Then it seems impossible to create a new Graph
array with the same (one) dimension, but with size=old size+1.
Johannes
On Tue, 28 Jan 2003 10:10:56 -0600 (CST), Dennis Knutson
(2,980 Views)
