Problem with EXE
Hello I Have problm with transforming LabVIEW program into EXE file.
I get this message in LabVIEW. Does anbody know how to solve this.
I also have question about how to make installer to load program in exe on another computer.
Thank you for your answer.
(2,827 Views)
here is what I message I got in LabVIEW.
(2,823 Views)
You need to provide some more details regarding this.
Are you getting the error while building the EXE?
If yes check any of the dependent VI is running.
If you are getting the error after building the EXE then find out the startup VI's that you have added.
(2,817 Views)
Provide more detail about this error.
Image seems to be a user created message in your Main Vi.Search  this message text in entire project.Do yiou get this error when you run your code?
Prashant
CLAD
KUDOS ARE WELCOMED.
PBP
Labview 6.1 - 2019
(2,806 Views)
