Problem with Configuring to use Silver Style with labview 2011 (32 bit)
Hi my friends.
I have installed labview 2011 32 bit. I have select silver style my default control style. but when I create new VI, labview doesn't create controls in silver style
the controls are created in modern style.
can any one help me to solve this problem?
with all my thanks: Saeid
(2,713 Views)
Accepted by topic author Saeid_Yousefpour
If you are dropping controls via the pallet, then it will drop whichever type's pallet you are in.  You are most likely in the Modern control pallet.  The setting you are referring to is when you create a control or indicator by right clicking on a primitive terminal.
(2,712 Views)
Playing around some more, I found that you can right click on a pinned pallet category and move it to the top.  Since the top category is by default expanded, you can set the silver control pallet to be the default controls in the pallet.
(2,711 Views)
