Problem with CEC PC-488 "create new" in MAX2.0
I need some help on this matter. I have an old CEC PC-488 gpib card installed on Windows 98 using CEC latest driver and its ok.
However, my installed LabView 6.0 didn't see it when I try to "create new" at Hardware interface in MAX (which BTW only display NI gpib interface driver).
Is there a special installation steps that I should do to overcome this problem?
Thankyou.
(2,739 Views)
MAX is only supposed to support National Instruments devices. It is their setup utility. You should still be able to use your card with LabVIEW though, you just won't be able to set it up thru MAX.
(2,739 Views)
