Problem while using LabVIEW for Trinamic TMCM 3110
Hello logipilot,
Unfortunately, the problem is not yet resolved. I am using a workaround way to calculate the values in between by interpolating after acquiring the data.
Best Regards,
Ankur
Message 11 of 12
(509 Views)
Hey!
Thank you for the reply.
I can´t interpolate, because I ´m changing the rotation speed all the time (, depending on the number of turns).
I just made a workaround myself:
First I calculate how many pulses are a full turn (depending on the µ-stepping parameter). ( µsteps^2 * 200 = steps / full rotation )
Next I count turns, because I need them for the timing of the other stuff.
When the motor counter closes in on "655360"  (or 17.432.576  or 34.210.000 ...) I use your single instruction vi and set the parameter number 2 (=actual position) to zero and start over again. While doing that I "remember" the old number of turns and add it to the calculated number (because it too starts over at 0).
Maybe this helps future readers.  😉
Thank you again for your example programs!  (see above) They are much better then the official examples (which have disappeared from the homepage anyways...)
God Speed
logi
Message 12 of 12
(486 Views)
