Problem while reading a configuration file which was edited in notepad
Hi All,
When I try to read a configuration file (which  was edited from notepad) using OpenG (Read INI Cluster) function I am not getting any outputs from the function. On debugging for the issue I tried reading the same file using Read from text file function. The output that I got is as follows:
[Server URLs]
Directory = "http://stb.site.com"
But the expected output is :
[Server URLs]
Can anyone tell me the reason for the junk data present in front of the section name and how to read the configuration file if any such issue occur. Thanks in advance.
(3,474 Views)
Accepted by topic author Prasaanth
See here: Config file "byte order mark"
(3,470 Views)
Also, in both cases, your GUI string value is missing the closing quotation mark.
(3,467 Views)
Thanks RavensFan. Sorry it is a Typo mistake. The actual outputs had closing quotations in both the cases
(3,450 Views)
