Problem while including the header file in C source code in CIN
While Creating code interface node....
In the C source code we are supposed to include the Header file "extcode.h".In my system i have installed
Turbo C. I couldn't able to find the above header files.When i am trying to use the above header file i am getting error,what could be the reason
(3,245 Views)
You need to point your turbo C to ..\labview\cintools which is where you will find the extcode.h and other h file and also the lib file.
Regards
Ray Farmer
Regards
Ray Farmer
(3,245 Views)
I was wondering how to use TC command line compiler to create lsb files .
thanks
(2,994 Views)
