Problem when starting DIAdem with LV Connectivity VIs
Wilken,
Are you sure this DLL is registered already when you try to unregister it? If its not already registered it won't be able to unregister the DLL.
Brandon Vasquez | Software Engineer | Integration Services | National Instruments
Message 21 of 26
(1,299 Views)
Hi Brandon,
I think the DLL is registered.
Regards
Andreas
Message 22 of 26
(1,294 Views)
That's just loaded in your GPI-Extensions, what I mean is, does Windows have this DLL in its registery (such as through regsrv32). If it does not, it would be one reason that unregistering it this way does not work.
Message 23 of 26
(1,284 Views)
Where should I find the DLL, if it is loaded?
Trying produces the same error as the command with /u.
Regards
Andreas
Message 24 of 26
(1,277 Views)
I´m sorry ...
Trying "regsvr32 /i "c:\Programme\National Instruments\DIAdem 9.1\AddInfo\gfsodbc.dll"" produces the same error as the command with /u.
Regards
Andreas
Message 25 of 26
(1,276 Views)
Hi Andreas,
We should be able to use OleView to see if the DLL is registered on your system. However, I'm wondering if this is a dead-end. The whole reason we pursued this angle is because you were receiving a DLL load error after DIAdem crashed.
Previously you said:
"Sometimes it helps to delete some tasks from the task-manager (nisvcloc.exe, nidmsrv.exe,nicitdl5.exe, nimxs.exe, nipalsm.exe, lkads.exe, lkcitds.exe, lktsrv.exe, nvsvc32.exe), but the last time it didn´t succeed and DIAdem stalls at "Lade: \ADDINFO\GFSODBC.DLL". After I started and ended DIAdem 8 I´m again able to start DIAdem 9.1"
We have already determined that loading DIAdem 8 does not allow you to load DIAdem 9.1 every time. Does the "Lade" (I assume that is load) error occur every time? If not, what other error messages do you receive.
Also, we never worked out a guaranteed fix - do you have to restart your computer?
Finally, we determined that this issue was a CAR but could be avoided if you simply opened DIAdem before you ran your test. Can you add code to make sure that DIAdem is loaded before you call the LabVIEW test? I would assume that this could also help resolve your issue.
Matt M.
Message 26 of 26
(1,252 Views)
