Problem using TDMS DLL in Matlab
Hi all -   I'm having a problem using the sample application to load TDMS files in Matlab (http://digital.ni.com/public.nsf/allkb/0EEADA99DC7D00A4862572E30037C3A2).
In Matlab, when I run the script that's included, I get the following error:
??? There was an error loading the library "C:\Files\ClosedLoop\MatLab TDM Example\bin\nilibddc.dll"
Error using ==> loaddefinedlibrary
The specified procedure could not be found.
Some searching around on the Matlab website reveals that this usually happens when a DLL references a procedure that it can't find.  Sure enough, if I use the program Depends to examine the TDMS DLL (nilibddc.dll) it shows a dependency on a DLL called DWMAPI.dll, which appears to be something related to Windows Vista.  Since I'm running Windows XP, it's obviously not on my system.  I did try downloading it, but it references *other* procedures from Windows Vista, so that didn't solve my problem.
Any ideas how to get around this problem?  Has anyone encountered something similar?
Cheers, Eric Tytell
(3,836 Views)
Hey, got the exact same problem Eric. Which Matlab are you using? I am using Matlab 7.5 (r2007b) on Windows xp sp2.
If you get a workaround or any clue let me know, as so will i of course
Good luck,
Raphael
(3,802 Views)
Did you ensure that you specified the following correctly?
"You can transfer the example code in the LoadTDM.m to any of your other M-script files. For example, if you copy the TDM dll and the header file into "C:\test\", you must specify the location in your m-script like this:
examplePath = 'C:\test';
hfile = [examplePath '\nilibddc_m.h'];
loadlibrary([examplePath '\nilibddc'], hfile);
Similar code can be found in lines 14 to 16 in the included m-script, which assumes that the TDM dll and the header file are in the same folder."
Also, which version of MATLAB® are you using? This example may only be used with version 6.5 or later. Are you using Windows XP?
MATLAB® is a registered trademark of The MathWorks, Inc.
Amanda Howard
Americas Services and Support Recruiting Manager
(3,773 Views)
Hi Amanda -
  I'm using Matlab R2007b on Windows XP.  The library path is specified correctly.
I tried the program on a different computer running Matlab R2006b (last year's version) and it runs fine.  So it must be something in the latest version of Matlab.  Any idea what it could be?
Eric
(3,768 Views)
Corollary discussion here.
(3,762 Views)
