Problem using Event Structure
Attached is my application where the user can drive the states transition trough buttons in the window.
I'm using event structure to monitor the buttons but there's a specific condition where it doesn't work properly.
If I push the buttons in the following sequence: "GO TROUBLESHOOT" and "PASSED", the buttons "RUN AGAIN" and "EXIT" seems to be locked in the next window.
However everything is OK if I push "FAILED" instead of "PASSED". I've already checked the option Lock Front Panel in the event structure but it doesn't affect the previous behavior. I really don't understand what is happening.
Thanks in advance for any help.
(2,904 Views)
Hello.
Unfortunately, I was unable to run the VI you sent, since Test Module General Error Handler.vi has a broken arrow when I open it in my computer (I don't know why). However, I ran into a very similar situation when I was trying to program an application using state machines and event structures as you are doing in the VI you attached. After some investigation, I noticed that the execution locks if there is an event for an event structure that is in a state of the state-machine different to the current state. So, my guess is that when you press "Passed" your state machine is not going to the state you think it is going. Put a probe at the output of the shift register where you store the current state to verify that this is so. I don't know if this is the
problem, but if it is, that probe is an easy way to get to the root of it.
(2,904 Views)
