Problem to open a simple folder
         Im having problem to open a folder ,,, i was using the component Open/Create/Replace file.vi to try create a folder,but isnt working . When i put the path way like C:\Registros ,where Registros dont exists yet, the component create a .dat  with this name (Registros.dat)  =\ ...
Someone can help me with it ?
Thx 😃
(3,422 Views)
hi
Why are you using Open/Create/Replace file.vi  to create folder? create folder and inside that you can create file. please read help for Open/Create/Replace file.vi
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,419 Views)
Cant find this vi ...
In labview 6.0 have this component?
(3,415 Views)
Accepted by topic author faelnpaiva
Hi dunno wha...,
the "create folder" function should exist in LV6.0. See this link:
http://forums.ni.com/ni/board/message?board.id=170&message.id=52455&requireLogin=False
If the folder "reg..." doesn't exists, then you have create it first. You don't need to open a folder, you only need to use a path to select the folder where you want to create a folder or a file, but all folders from the path has to exists.
Mike
Message Edited by MikeS81 on 06-30-2009 02:27 PM
(3,401 Views)
