Problem to open Trace Tool session
I try to use the "Stop and Save" VI then the "Load and Send" VI, or the "Stop and Send" VI.
The Trace Toolkit interface on the supervisory PC displays the following message : "Loading ..." but never goes away.
It may be linked to the newest version of NI DAQmx 7.4 I installed recently ?
Tank you for answer.
PS: I join the session file (.log) I created.
(2,600 Views)
The NI-DAQmx 7.4 can be used with the Trace Toolkit.
A possibility is that drivers had been corrupted.
Then you could try to uninstall and install it again.
If you still have the problem try to perform an example to reproduce the problem and send it.
regards,
Marc L.
NIF
(2,560 Views)
