Problem to auto-center VI
Hi, I'm running a keypad program in Labview 5.0.  When I click the white arrow, the top bar and the scroll bars disappear to leave me only with the keypad.  This works perfectly, except that the keypad is not centered in the middle of the screen.  I have selected the auto-center option in the VI setup menu, but it doesn't seem to work.  I have to manually place the keypad with the scroll bars and then click the white arrow and hope that it is going to be centered.  The problem is that this is used with a small touchscreen and this isn't easy to do fine adjustments.
Am I doing something wrong or is there an easy way to solve my problem without using programmation?
Thanks.
(2,662 Views)
I don't remember ever seeing a problem with the auto-center option. You could post the VI. I can't run it in LabVIEW 5 though, since I haven't had that installed since about 10 years ago. The best I could do was to see if the problem exists in a later version of LabVIEW.
(2,645 Views)
