Problem that Calling DLL with 2D array input in LabVIEW
I have to call a DLL which a 2D character array as an input, the DLL can't be changed any more because some odd reason. How can I call this kind of DLL in LabView?
Any help shall be appreciated.
Thanks, Steven
(3,373 Views)
Hi Steven,
      Can you post the DLL function's prototype, or even some of the code?
Cheers.
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(3,350 Views)
Hello, Thanks for your reply.
The definition of one function(get the QTY of the loading box currently using and its ID)
Int  binResLists (char *ids[ID_LENGTH + 1], int maxNum)
output:         char *ids[ID_LENGTH + 1]          // a array used for store the ID read back.
Input:           int maxNum                                  //  specify the maxmum loading box.
how many loading box using will be returned after calling this function
Explaination about this function in the DLL spec as below:
" char ids[256] [ID_LENGTH + 1]  or  char ids[256] [9]       // Declaration.
  int resNum = binResLists ( ids, 256);                         // Allowed maxmum loading box is 256,resNum is the number of loading box."
I don't know how to allocate the memory for the 2d array in LabVEIW. the DLL in attachment but no any code cos i have not get started till now.
Thank you again.
Steven
(3,344 Views)
Hi Steven,
      The attached VI shows how to pre-allocate the table-memory in LabVIEW.  Unless you know the "Calling convention" you'll have to experiment.  Also, maxLoadingBox (int) INPUT might be 16bits instead of 32bits.
Don't feel bad if you crash a few times before solving the details. Smiley Wink
Cheers!
(3,321 Views)
