Problem running DNP3 executable?
I have problems running the build executable of a DNP3 application.
Everything seems working with the source code, but when I run the executable I get an error at the Master Creation step.
I’m using Labview DNP3 Toolkit 2.1.
Could someone give some help?
Thank you
MorganSch
(3,254 Views)
Hi MorganSch,
I would recommend posting this over at the Industrial Communications forums, where we monitor the forums for issues like these.  Are you running this executable on a Windows machine?  From the screenshots, this seems to be the case.  Additionally, the error seems to indicate that this is being run on Windows as well:
Error -44247
Possible Reason(s): DNP3 applications distribution is not supported on the Windows platform.
With DNP3 2.1, we only support the following:
The NI-IndCom for DNP3 driver supports unlimited deployments to the following NI real-time hardware targets: CompactRIO, NI Single-Board RIO, and PXI. The driver is not licensed for deployment on Windows-based computers.
Matt S.
Industrial Communications Product Support Engineer
(3,238 Views)
Hello Matt
Thank you for your input. Really the application is on Window system and I don’t have the NI target hardware support.
Regards
MorganSch
(3,230 Views)
