Problem related USB Virtual COM PORT using PDA module 8.2 on Windows CE
I am working on tranferring my application developed on LV 8.2 to a Single-board computer(SBC) running Windows CE 5.0. I am using LV PDA module 8.2 to achieve this. My problem lies in finding the port number of the Virtual COM Port on the SBC. I need to connect a USB RF modem from Maxstream to this SBC and to talk to it using VISA. I have installed the required drivers from Maxstream for converting the USB port to a virtual COM PORT. What is a way to figure out the COM PORT number on a Windows CE device? For a PC, I can see the COM PORT in the device manager but I do not know how to find this in Windows CE. . Also, I have tried using "VISA Find resource" function ..it works on a PC but I do not get anything in the Win CE device.
Any help would be much appreciated.
-Shruti
(4,267 Views)
Shruti,
Is there a way to verify that the Maxstream driver successfully provides you with this virtual COM port? Essentially, what I mean is that if you did not have LabVIEW on this device, how does Maxstream prove that their driver is functional? Does it come with additional software that would be used to configure the USB RF modem? In any case, we would want to try opening any terminal program (like the hyperterminal) to determine what ports are listed for communication. I hope this is useful for you. Please post back when you are able to give this a try. Thanks,
Mike D.
(4,250 Views)
