Problem receiving analog input from Arduino
Im developing a project where i pretend to activate a valve using communications between Arduino and Labview. In this project , after i send a command to arduino , it starts sending an analog signal to Labview . I've tested the signal on arduino serial port  and with and RCOM software , and all works correctly . But, when Labview receives the data it usually jumps a line between data received fragmenting it. Example : REceives 500, 523 , 544, but Posts it as 500, 5 ,23 , 544. Can anyone help me with this? I'll post VI if necessary. Im using Arduino UNO at baud rate 9600, im using a 20 ms delay on arduino sending the data , and am acquring it on labview at a 5 ms rate.
Another , totally unrelated issue is that i can't understand how i can,  import a one column data from a .txt file , and graph it on Labview as a time depending signal, i want to be able to control the time difference (dt) between each row .
If anyone can help , ill be very thankful.
Cheers,
José
(3,801 Views)
Hi Josep,
There is a user group for Arduino and Labview: https://decibel.ni.com/content/groups/labview-interface-for-arduino
Posting your question there will probably be the best place to get an answer.
-CC
"If anyone needs me, I'll be in the Angry Dome!"
(3,797 Views)
You can see an example for analog reading, make a program in LabVIEW to test and verify the correct operation of our program in the Arduino , we will make the reading of data transmitted by the Arduino from the serial port on the card installed , proceed to read the COM port
https://decibel.ni.com/content/docs/DOC-33278
(3,521 Views)
