Problem reading txt file
Hi
I have a shell cluster where I type different data for my file. Then I save this to txt file. The problem is when I want to open the file and use the data for the same shell cluster, which is now an indicator. Can someone help me with this??
(2,993 Views)
You need to replace the Initialize Array function (which creates an empty array the way you have it connected) with the Spreadsheet String to Array function. Wire a Line Feed constant to the delimiter input and "%s" to the format string input.
Lynn
(2,988 Views)
Thank you on your fast reply. How do I connect the array terminal to the shell cluster indicator??
I am new at this..
Boris
(2,978 Views)
Hi Boris,
see the attached example. It is better if you insert your input data into the save event, because you then save the newest values.
Mike
(2,964 Views)
Thank you Mike  !!!!
Boris
(2,961 Views)
