Problem reading a vi's description property in an executable
Hi guys
I run into a very strange problem. I have a vi (attached) which reads the description property of a vi. The vi is inside a llb. I use the function "current vi's path", strip it and then build a new path with the name of a vi which is in the same llb. When I run my program in the IDE it works without any problem, but if I build the executable it doesn't work anymore. I logged all the paths - all of them are correct, but I don't get the description property of the necessary vi.
Basically I have the toplevel-vi in llb 1, the attached vi in llb 2 and it is used in another vi which is called in the toplevel-vi and located in llb3.
Is there anyone who could help me out?
Many thanks in advance.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,124 Views)
Hi Thomas,
in your application all vi´s lie side by side. So the path you get from "currentvispath" is:
directory\yourapplication.exe\actual.vi
To see it better you can simply add an indicator to the currentvispathvi and show it in your application.
Mike
Message Edited by MikeS81 on 01-29-2008 10:15 AM
(3,119 Views)
Hi Mike
Yes, I know. As I wrote all the paths are correct, otherwise I would get an error when opening the vi-reference (Err 7 - file not found). I am wondering why I can read the description property but don't get any text.
As mentioned in my first post all works correctly if I let the program run in development mode. If I run the exe I don't get anything.
Thomas
Using LV8.0
(3,097 Views)
Are you using the "default save settings" in the build properties (under the Source File Settings page)? This removes the front panel and block diagram which I suspect may remove the VI description text. I haven't tried a test case so I'm guessing here.
(3,093 Views)
Hi Thomas,
I know that this is just the opposite side of your problem, but you can ve a look over here for more details, I think...
http://forums.ni.com/ni/board/message?board.id=170&message.id=180194&requireLogin=False
Sorry, if it is totally out of context.
- Partha ( CLD until Oct 2027 🙂 )
(3,084 Views)
That's exactly what I've been looking for..
As usual - if you don't use something for a long time, you forget it.
Anyway - thanks Bill. You helped me a lot.
Using LV8.0
(3,077 Views)
