Problem printing CWGraph3D
I am trying to print vi front panel containing CWGraph3D control but I only get pop-up error message
"An error occured. The control was unloaded". The vi crashes, print comes out with the container containing no graph only "Control could not be loaded" text.
Is that common to all ActiveX containers?
I use Print Panel to Printer method
(2,910 Views)
No, this is not common. There may be a problem with the control. Can you print the panel with File>>Print?
Instead of dropping the activeX container and inserting the control, use 3D Parametric Graph from the Graph palette. Delete the 3D Parametric Surface.vi, that gets created on the block diagram when this object is used, and leave just the control reference. I tried this in LabVIEW 6.1 and didn't have problems printing.
Zvezdana S.
(2,910 Views)
