Problem opening the file
Hi ALL,
I have a problem to run a VI in my laptop. I'm using LabVIEW 8.6 and its installed in my PC also my laptop, Apple. I could run my program easily without any problem with my PC but it doesnt work with my Apple.
Whenever I would like to run it, the error shows
| TDMS Open : Contains unwired or bad terminal |
This problem also occured to TDMS Close and TDMS Write.
The only solution I did was deleting all these three function.
After running the program, the other problems occured where the graph shown is different with what I have in my PC.
Hope someone could help me on this matter.
Thank you.
Firdaus
(3,851 Views)
Check all of your path functions.
Windows, Mac, and Linux all use different formats for paths.
Just check that you arent using any Windows specific formats.
Cory K
(3,850 Views)
Which OS you use? TDMS is not supported on Mac.
(3,847 Views)
Thanks all for reply.
Cory K, do you have the sample of the path?
(3,841 Views)
Windows:
C:\Documents and Settings\File
Mac:
/Mac HD/Documents/File
Unix:
/Documents/File
But as Yongqing Ye said, Macs do not support the TDMS file type
Message Edited by Cory K on 05-29-2009 10:43 AM
Cory K
(3,837 Views)
Hi.
Since my Apple using Mac, concluded that TDMS doesnt fit with it.
Thanks a lot.
Firdaus
(3,831 Views)
(3,812 Views)
