Problem on capturing Real time data with DT 9816 DAQ using LabVIEW
Hello All,
I am facing some problems while capturing real time data with DT 9816-S DAQ (Measurement Computing DAQ) using LabVIEW. I want triggered data collection (1 channel) with the mentioned DAQ (DT 9816-S) using LabVIEW. I have installed some additional libraries (LV Link 3.0) for this purpose.
Using those VIs, I have constructed the block diagram. This is as follows:
But, while running It shows "invalid trigger".  I have used 'Digital Trigger' in this case. However, I have also changed the trigger to 'Analog' but the issue still persists.
Any help regarding this will highly be appreciated.
Thanks and regards,
Subhadeep Basu
(1,804 Views)
Hello All,
I want to capture simultaneous multi-channel (4 channel) triggered data using DT 9816-S (Measurement Computing DAQ)  daq with LABVIEW. I have downloaded and installed "LV Link 3.0" for this purpose. However, I am facing some problems to acquire those. The block diagram is shown below
But, whenever, I am running it to capture data, it says "Invalid task"
Can anyone please help how to fix this issue.
Thanks and regards,
Subhadeep Basu
(1,777 Views)
Hi subha,
please don't create duplicate threads for the same problem!
Did you ask MeasurementComputing for support on their products?
(1,756 Views)
Ok,
I asked Measurement computing in this regard. Waiting for their reply. But the issue is not resolved yet.
Thanks and regards,
Subhadeep
(1,743 Views)
Since they are the seller of the hardware (and associated driver software), they also are the main contact. There might be of course a small change that another user of this hardware is on this forum, but it is a small change. And that user needs to happen to be online, read your request, feel in the mood to react and give you an answer. Most users only come here when they have a problem themselves.
Rolf Kalbermatter  My Blog
(1,734 Views)
