Problem on Converersion from array to string
Hi everyone,
I have an array of type 'string', which all the elmenmts are same:  '9.91E37'.
I am going to make an array of length 64 (64 elements) of value '9.91E37' with a comma between each of them (Except the first one and the last one).
The result is supposed to be like this:   9.91E37,9.91E37, ................ , 9.91E37
Is there any way to do this quickly ?  I don't really have to use that array but only needs a string with 64 elments, it must got some methods to do it in labview other than typing 64 of them in a string constant.
Thanks a lot,
+Kunsheng Chen
(3,151 Views)
Accepted by topic author Kunsheng Chen
Try "Array to spreadsheet string" with a comma as delimiter.
(To make the string array, you could use "initialize array" with the desired string as element and lenght=64.)
Message Edited by altenbach on 03-12-2009 12:43 PM
(3,149 Views)
Thanks a lot! it works like a charm!
+Kunsheng
(3,140 Views)
