Problem nesting combo boxes between them LabVIEW
To be honest with you, I'm new to LabVIEW and I didn't understand your explanation very well, can you give me a protocol please to help me solve my problem? I haven't been able to solve my problems for 2 or 3 weeks
Thank you
Message 11 of 16
(105 Views)
Hi Problem,
Have you done any of the training resources offered in the header of the LabVIEW board in this time?
Did you examine the state machine example coming with LabVIEW?
(State machines are very basic software constructs and you should be able to implement them.)
As described in message #2 your problem could be reduced to a state machine, with states of "get user input" and "parse/provide the next piece of information"…
Message 12 of 16
(91 Views)
The problem is I want it to fill up dynamically and not have it pre-filled
Message 13 of 16
(61 Views)
Hi Problem,
Yes, we know.
That's why I suggest to implement a state machine that will fill the controls/data structure dynamically…
Message 14 of 16
(54 Views)
You say "nested", but do you really mean they are dependant on each other? If you select 'A' on the 1st one, then 2nd one has 1,2,3 as choices, but if you select 'B' , then 2nd has 4,5,6?
Qestit Systems
Certified-LabVIEW-Developer
Message 15 of 16
(15 Views)
See if this gives you any ideas.
Qestit Systems
Message 16 of 16
(12 Views)
