Problem integrating MKS Source Integrity with LabVIEW
I'm trying to integrate MKS Source Integrity with LabVIEW but when I goto to the dialog under Tools > Source Control > Configure Source Control the dialog that pops up doesn't list MKS SI in the Provider Name drop down list.  I've looked at some KB's and the only thing I found is that the drop down list is populated based on entries in my registry.  Which key(s) need to be listed for MKS to be detected?  I'm using LabVIEW v8.2 and MKS SI v7.3e
(2,840 Views)
In order for MKS to show up in the list of providers, the MKS integration to Visual Studio must be installed/enabled. This integration allows development programs (like LabVIEW) to use a common interface to communicate with MKS. I believe you have to enable the integration from within the MKS environment. I do not remember where the menu option is, but once you do this, you should be able to see MKS as a provider in LabVIEW.
George M
(2,833 Views)
