Problem installing Labview Community
Hi
I am trying to install labview community on windows 10 and get this error,
An error occurred while upgrading from package 'ni-ceip (21.5.0.49152-0+f0)' to 'ni-ceip (25.0.0.49234-0+f82)'.
Additional error information:
• An error occurred while creating a process to run command '"C:\Program Files\National Instruments\Shared\CEIP\niceipsettings.exe" -uninstall'.
This happened before so I uninstalled previous versions of Labview with package manager but the problem persists. Any suggestions?
The problem is mentioned in this post What-is-ni-ceip-x86-error  but it is out of date, obviously been a problem for a while.
(1,654 Views)
Hi
I am sorry that you are experiencing this issue. I am the product owner for ceip so I will have the team look into this. Just for reference, what version of LabVIEW did you previously have installed?
Chris
(1,584 Views)
Hi Chris,
I seem to have had every version of Labview since 2014 through updates. This is the error message I was getting;
An error occurred while upgrading from package 'ni-ceip (21.5.0.49152-0+f0)' to 'ni-ceip (25.0.0.49234-0+f82). Hope that helps.
Ed
(1,544 Views)
Hi Ed,
Apologies for the delayed response. I was expecting an email about a response, but our NI emails just got turned off so it got sent off to the void.
The team hasn't been able to replicate this on any of their systems. They were wandering if you could send the Package Manager logs to us as that might help us. The instructions on how to get those logs can be found here: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHe6CAG&l=en-US
I have one more idea that I want to try. I will work on that and respond about that by the end of the week.
Chris
(1,465 Views)
I am getting the same problem. Also uninstalled Labview (version 2024 q1 32 bit) with the package manager. Now I try to reinstall Labview 2024 q1 32 bit for hours and it does just not work...
What log files do you need?
My problem was that i was playling around with Labview 2026, because I thought our software might work with it. Well i learned the hard way: it definitely does not. And now getting back to 2024 is a horrible procedure. I was still having some packages that were 2026 and did not work, although i already used Labview 2024. So i uninstalled more and more of the whole NI suite... Until I went to far, I guess..
Now i am at the point where i am getting "
Beim Installieren eines Pakets trat ein Fehler auf: ni-ceip (23.8.0.49234-0+f82)
Zusätzliche Fehlerinformationen.
Fehler beim Erstellen eines Prozesses zur Ausführung des Befehls '"C:\Program Files\National Instruments\Shared\CEIP\ConfigStoreUtility.exe" migrate registry json Ceip'."
English:
An error occurred whilst installing a package: ni-ceip (23.8.0.49234-0+f82)
Additional error information.
Error creating a process to run the command “‘C:\Program Files\National Instruments\Shared\CEIP\ConfigStoreUtility.exe’ migrate registry json Ceip”.
... and no Instruction/Tutuorial or AI was able to help me with that.
(360 Views)
I talked to our installer expert about this. In general, trying to revert back to an older state is really difficult. I am sorry that you are hitting this issue.
His recommendation was to first try running that EXE directly with this command:
C:\Program Files\National Instruments\Shared\CEIP\ConfigStoreUtility.exe migrate registry json Ceip
That might give us more to work with.
You can also follow the instructions on this page to access the log files. The most recent log file should be sufficient there.
(318 Views)
