Problem in taking counts the motor moved at specific time intervals
I've attached the program I'm using on LABVIEW to control an AC servo motor.  What I want is the number of counts it has moved from the Position block,  which I convert to cm before saving it in a file through the measurement block. I want to get the counts every 15 ms, but I can't. The min I get is 86 ms. Could you please let me know why and how do I fix this issue?
(2,058 Views)
I'm having a real hard time seeing this, even if I blow it up.  Is there any way you can at least copy a screen shot from the PC - or better yet, the actual code - to a place you can upload it to?  Like maybe using a USB drive?
Bill
CLD
(Mid-Level minion.)
(2,041 Views)
There's another screenshot in the doc
I've attached the LABVIEW file as well.
(2,030 Views)
