Problem in synchronization between a Task and a timed loop
This is the second time that I post this message because I realized my question landed on the wrong side of the forum and no one has answered.
So I try for a second last time:
Hi everybody,
As usual I need help. I have attached my .vi to let you understanding the source of my first problem.
Sorry for the German names of the Vis.
I have a PCI 6289 installed on a  PC Desktop real time target.
I want to have the smaller jitter possible between Input and output. Since for the moment I have a jitter of 0.1 ms at 40 KHz sampling rate I thought that the cause of this random delay could have been the asynchronization between the While timed loop clock and the Hardware timing clock.
So I tried to synchronize them with the use of a Timing source.
Unfortunately the result is not the expected one.
When I press the execution arrow  all is happening is a millisecond or less of execution and then the program stops automatically without any error message,
Why the Vi is not working? Someone has an Idea?
Many thanks.
Principiant
(2,755 Views)
My first thought would be... you want less than 1mS resolution on a PC target? ... Running Windows?
To get a better feel for the error, monitor the error output of the timed loop itself.
Richard
(2,713 Views)
Hi thans for your answer,
The discussion and the problems are already advanced in another thread.
If you want to follow the discussion see here:
 http://forums.ni.com/ni/board/message?board.id=170&message.id=345956#M345956
Bye
Principiant
(2,700 Views)
